Editing a Log Clearance Task
To edit a log clearance task
  1. On the Navigation Tree, click Report Warehouse, then click Maintenance and select Log Clearance Tasks. The Log Clearance  Tasks page appears.
  2. Click the name of the log clearance task you want to edit or click anywhere on its row, and then click clip0003.
    The Log Clearance Task page appears. For details about how to change its items refer to Adding a Log Clearance Task.
  3. Make the necessary changes and click Save. The system saves the modified log clearance task to the database and displays the updated Log Clearance Tasks page, if the operation is completed successfully.
