Editing a Role
To edit a role
  1. On the Navigation Tree, click Rights and Privileges, and select Roles.
  2. Click the name of the role you want to edit or click anywhere on the row, and then clickclip0003. The Role page appears.
  3. Make the necessary changes. For more information on how to change its items, see Adding a Role.
  4. To grant access rights, select an appropriate tab at the top of the page. The following tabs are available in the Edit mode:
    • Role tab allows you to modify the role name and description and grant common and specific privileges to the selected role.
    • Settings tab allows you to modify the notification settings, particularly the number of days when an alert about license expiration will be shown.
    Note: The Defined check box is disabled by default. If the setting is not “Defined,” then the global setting under System Preferences applies.
  • Models tab allows you to assign models to the current user. To do this, drag appropriate items from the left pane to the right pane, and click Save.
  • Automator Processes tab allows you to assign automator processes to the current role. To do this, select a search from the list, then drag appropriate items from the left pane to the right pane, and click Save.
  • Visual Processes tab allows you to assign visual processes to the current role. To do this, select a search from the list, then drag appropriate items from the left pane to the right pane, and click Save.
NOTE: Processes created in older versions of Monarch Server (e.g., v13.2) are assigned to all users.
  • Automator Projects tab allows you to assign projects to the current role. To do this, drag appropriate items from the left pane to the right pane, and click Save.
  • Workspaces tab allows you to assign workspaces to the current role. To do this, drag appropriate items from the left pane to the right pane, and click Save.
  • Change Lists tab allows you to assign change lists to the current role. To do this, drag appropriate items from the left pane to the right pane, and click Save.
  • Folders tab allows you to assign folders to the current role. To do this, drag appropriate items from the left pane to the right pane, and click Save.
  • Named Paths tab allows you to assign named paths to the current role. To do this, drag appropriate items from the left pane to the right pane, and click Save.
Note: You can copy rights of a role by clicking the Copy Profile button available on the aforementioned tabs, except the Views and Report Security tabs.
  1. Make the necessary changes and click Save
    The system saves the modified role to the database and displays the updated Roles page, if the operation is completed successfully.
