Filing Tasks
A filing task is used to archive reports into a storage volume. After you have configured a filing task, you can run it via a filing process.
All filing tasks used in the system are listed on the Filing Tasks page. To display this page, click Report Warehouse on the Navigation Tree, then click Document Management and select Filing Tasks.
Use this page to add, edit, or remove a filing task.
