Global User Settings
Use the Global User Settings page to set your global settings. To access this page, on the Navigation Tree, click System Settings, select System Preferences, and click the Global User Settings tab at the top of the page.
The Global User Settings page contains the following settings:
NOTE: When no pane is selected, the MSClient home page will be empty.
After you made your changes
To save changes to global user settings, click the Save button.
To reset the changes you just made, click the Clear button.
To cancel the operation without changes, click the Cancel button.
