Locations Management
To manage your location preferences
  1. On the Navigation Tree, click System Settings and select System Preferences.
  2. On the displayed page select the Locations Management tab.
To set the default location name for all the object that have location as their parameter
  1. Select location name from the Default Location list.
  2. Click the Save button.
To add new location
  1. Click the Add New Location button plus2 and enter the new location name in the Location field.
  2. Click the Save button. The new location will appear on the list.
To edit location
  1. Click the name of the location you want to edit or click anywhere on its row, and then click clip0003.
  2. Make you changes.
  3. To save your changes, click the Save button.
To remove location
  1. Click clip0004 at the end of the row with the location you want to delete.
  2. Click Delete to confirm.
NOTE: In case of single server installation refer to the Configurator Guide in the Monarch Server Installation Guide to change location settings.
