PostProcess Script
The PostProcess tab is part of the Script Editor. Use this tab to specify any cleanup or shutdown operations to be performed after the last job of a process completes.
The PostProcess tab includes the following settings:
  • Script field: Displays the existing post-process declarations.
  • Compile/Run: Compiles/runs the script and if the script is compiled without errors runs it on the specified for testing location.
  • Insert Script: Allows you to quickly generate VB.NET script for frequently used tasks. Click to select the necessary options. For details, refer to Inserting a Script section.
  • Clear: Removes the scripts from the script field.
  • Locations for testing: Displays the location used for testing the script before deploying it.
