Project File Revisions
You can view, edit, restore or delete the necessary project file revision any time using the Revisions tab.
To edit a project file revision
On the Navigation Tree, click Server Library and select Projects.
Click the name of the project file you want to edit a revision for or click anywhere on its row, and then click
On the displayed page, select the Revisions tab.
Click the Open icon
to open the project file in the Project Editor. -
Edit the project file if necessary and click the Commit button. The Project page is displayed.
Click Save.
The system saves the modified project file as current and displays the updated Projects page, if the operation is completed successfully.
To restore a project file revision
Click the name of the project file you want to restore a revision for or click anywhere on its row, and then click
Choose the revision to be restored, and then click the corresponding Restore icon
A prompt displays. Click Ok to proceed.
The restored revision occupies the latest entry in the list of revisions in the Revisions tab.
To delete a project file revision
Click the name of the project file you want to delete a revision for or click anywhere on its row, and then click
Choose which revision to delete by clicking anywhere on its row, and then click the Delete button
found at the end of the row or on the top left-hand side of the Revisions page. -
A prompt displays. Click Delete to proceed with the deletion.
