Running a Maintenance Task
When you finish configuring a maintenance task, you can run it to perform the specified maintenance action.
To run a maintenance task
  1. Configure a maintenance process.
NOTE: If the desired maintenance process already exists, skip down to step 2.
  1. Assign the maintenance task to it.
  2. Run the maintenance process. When the process is executed, the tasks assigned to it will be run as well.
