RunTimePID
This block implements a tunable PID. During the simulation, the coefficients of the PID can be manually tuned.The current value of the gain is equal to the Value multiplied by the Factor
    RunTimePID
Activate/Dynamical
The RunTimePID block implements a PID controller. The PID controller calculation (algorithm) involves three separate parameters: Proportional, Integral and Derivative. The Proportional value determines the reaction to the current error, the Integral value determines the reaction based on the sum of recent errors, and the Derivative value determines the reaction to the rate at which the error has been changing. The weighted sum of these three actions is used to adjust the process via a control element such as the position of a control valve or the power supply of a heating element. The value of the parameters can be tuned during the simulation.
The left end of slider represents the Min value.The right end of slider represents the Max value.The number of ticks is (Max-Min)/Step.The slider corresponds to a nominal value based on its position with regard to ticks.The real PID parameter is calculated by Value*Factor.
RunTimePID_0
p_value
Value
Int value. The current value of the slider.
Scalar
p_min
Min
Int value. The minimum value of the slider.
Scalar
p_max
Max
Int value. The maximum value of the slider.
Scalar
p_step
Step
Int value. The step taken by the slider.
Scalar
p_factor
Factor
Real Value. the factor used to convert the slider value to the gain value.
Scalar
RunTimePID_1
i_value
Value
Scalar
i_min
Min
Scalar
i_max
Max
Scalar
i_step
Step
Scalar
i_factor
Factor
Scalar
RunTimePID_2
d_value
Value
Scalar
d_min
Min
Scalar
d_max
Max
Scalar
d_step
Step
Scalar
d_factor
Factor
Scalar
N
Filter coefficient
Scalar
Port 1
explicit
input
1
Port 2
explicit
output
1
Port 3
activation
input
1
Advanced Properties
NameValueDescription
always active
yes
direct-feedthrough
yes
PID block is direct-feedthrough unless the proportional gain (Kp) is zero (0).
zero-crossing
no
mode
no
continuous-time state
no
discrete-time state
no
Diagram
RunTimePID
See Also
