LookupTable2D_port
This block approximates a non-linear function using interpolation on data provided as a "2D-table".
Activate/LookupTables
Method | Interpolation method | Interpolation method. Default: bilinear. | String | 'Linear' |
DoOutside | Result outside the table range | Action to be taken with the result outside of the table range. | String | 'Zero' |
EventGen | Apply zero crossings | Turn this parameter on to detect the zero crossings. Default is on. | Scalar | 0 |
externalActivation | External activation | Specifies whether the block receives an external activation or inherits its activation through its regular input ports. When External Activation is selected, an additional activation port is added to the block. By default, external activation is not selected. | Number | 0 |
y | explicit | output | 1 | |
u1 | explicit | input | 1 | |
u2 | explicit | input | 2 | |
U1 | explicit | input | 3 | |
U2 | explicit | input | 4 | |
Y | explicit | input | 5 | |
Port 7 | activation | input | externalActivation |
