Assignment
Assigns value(s) to specified element(s) of the input matrix.
Activate/MatrixOperations
Specified elements of input matrix is assigned with the input labeled 'u'. The specified rows or columns can either be represented by a vector of row/column numbers as the block parameter, or fed externally with an optional input.
assignx | Index vector I | Index selection method for the first dimension. | Structure | |
assignx/x_selectall | : (all) | Select all rows. | Number | 0 |
assignx/x_vectorindex | Defined as parameter | Select rows by specified indices. | Number | 0 |
assignx/x_startingindex | i=I(1) defined as parameter | Select rows by specified starting index. | Number | 0 |
assignx/x_startingindexdecreasing | i=I(1) defined as parameter (decreasing) | Select rows by specified endinging index. | Number | 0 |
assignx/x_vectorindexport | Defined by input | Select rows by the indices provided externally | Number | 0 |
assignx/x_startingindexport | i=I(1) defined by input | Select rows from starting index provided externally. | Number | 0 |
assignx/x_startingindexportdecreasing | i=I(1) defined by input (decreasing) | Select rows from ending index provided externally. | Number | 0 |
x_vector_index | Index parameter | Structure | ||
x_vector_index/x_vi | Index vector I parameter | Cell of vectors | ||
x_starting_index | Index parameter | Structure | ||
x_starting_index/x_si | i=I(1) parameter | The indices of selected rows. | Cell of vectors of size 1 | |
x_starting_indexdecreasing | Index parameter | Structure | ||
x_starting_indexdecreasing/x_si | i=I(1) parameter | The index of starting row. | Cell of vectors of size 1 | |
assigny | Index vector J | Index selection method for the second dimension. | Structure | |
assigny/y_selectall | : (all) | Select all columns. | Number | 0 |
assigny/y_vectorindex | Defined as parameter | Select columns by specified indices. | Number | 0 |
assigny/y_startingindex | j=J(1) defined as parameter | Select columns by specified starting index. | Number | 0 |
assigny/y_startingindexdecreasing | j=J(1) defined as parameter (decreasing) | Select columns by specified ending index. | Number | 0 |
assigny/y_vectorindexport | Defined by input | Select columns by the indices provided externally. | Number | 0 |
assigny/y_startingindexport | j=J(1) defined by input | Select columns from starting index provided externally. | Number | 0 |
assigny/y_startingindexportdecreasing | j=J(1) defined by input (decreasing) | Select columns from ending index provided externally. | Number | 0 |
y_vector_index | Index parameter | Structure | ||
y_vector_index/y_vi | Index vector J parameter | The indices of selected columns. | Cell of vectors | |
y_starting_index | Index parameter | Structure | ||
y_starting_index/y_si | j=J(1) parameter | The index of starting column. | Cell of vectors of size 1 | |
y_starting_index_portdecreasing | Index parameter | Structure | ||
y_starting_index_portdecreasing/y_si | j=J(1) parameter | Cell of vectors of size 1 | ||
onebased | One-based indexing | To index a matrix, start from one when checked, start from zero when unchecked. | Number | 0 |
externalActivation | External activation | Specifies whether the block receives an external activation or inherits its activation through its regular input ports. When External Activation is selected, an additional activation port is added to the block. By default, external activation is not selected. | Number | 0 |
Y | explicit | input | 1 | |
U | explicit | input | 2 | |
Port 3 | explicit | input | 1-assignx.x_selectall*1-assignx.x_vectorindex*1-assignx.x_startingindex*1-assignx.x_startingindexdecreasing+1-assigny.y_selectall*1-assigny.y_vectorindex*1-assigny.y_startingindex*1-assigny.y_startingindexdecreasing | |
Y | explicit | output | 1 | |
Port 5 | activation | input | externalActivation |
Advanced Properties
| Name | Value | Description |
always active | no | |
direct-feedthrough | yes | |
zero-crossing | no | |
mode | no | |
continuous-time state | no | |
discrete-time state | no |
