Sink
This block imposes constraints of signal dimension and data type on the link with which it is connected.
Activate/SignalProperties
dim | Dimensions | Vector of size 2 | ||
intyp | Datatype | Defines the datatype of the input.Supported types are : double, complex, int32, int16, int8, uint32, uint16, uint8, boolean, inherit. | String | 'double' |
externalActivation | External activation | Number | 0 |
Port 1 | explicit | input | 1 | |
Port 2 | activation | input | externalActivation |
Advanced Properties
| Name | Value | Description |
always active | no | |
direct-feedthrough | yes | |
zero-crossing | no | |
mode | no | |
continuous-time state | no | |
discrete-time state | no |
