VariableFlowPump
Partial Pump
HydraulicsByFluidon/Components/Pumps
The component VariableFlowPump constitutes a model of a flow source in which the delivery is calculated from the given nominal flow, the input signal and the leakage.
Both internal and external leakage depend on the adjacent pressure difference.
The parameter nominalVolumeFlow refers to the flow at Port A (suction side).
The valid range of the input signal at port setpoint is 0 < signal < 1. Therefore 1 corresponds to 100 % of the nominal volume flow.
VariableFlowPump does not provide a model of the physical design of a pump but only copies its characteristic features. Thus, physical parameters (e. g. inertia moment or hydraulic-mechanical efficiency) are not parameterized.
mo_nominalVolumeFlow | nominalVolumeFlow | Nominal volume flow, A -> B | Scalar | |
mo_deadVolume | deadVolume | Dead volume at ports | Scalar | |
mo_leakageFlowRateInternal | leakageFlowRateInternal | Internal leakage: volume flow | Scalar | |
mo_leakagePressureDiffInternal | leakagePressureDiffInternal | Internal leakage: pressure difference | Scalar | |
mo_leakageFlowRateExternal | leakageFlowRateExternal | External leakage: volume flow | Scalar | |
mo_leakagePressureDiffExternal | leakagePressureDiffExternal | External leakage: pressure difference | Scalar | |
mo_leakageReferenceDensity | leakageReferenceDensity | Reference density for volume flow and pressure difference | Scalar | |
mo_useLeakagePort | useLeakagePort | Enable leakage port, otherwise implicitly connected with tank | Number | 0 |
mo_forwardFluidProperties | forwardFluidProperties | Forward fluid properties between ports | Scalar | true |
mo_volumeFlowA | volumeFlowA | volumeFlowA | Structure | |
mo_volumeFlowA/fixed | fixed | Cell of scalars | true | |
mo_volumeFlowA/start | start | Cell of scalars | ||
mo_volumeFlowB | volumeFlowB | volumeFlowB | Structure | |
mo_volumeFlowB/fixed | fixed | Cell of scalars | true | |
mo_volumeFlowB/start | start | Cell of scalars | ||
mo_pA/start | start | Cell of scalars | ||
mo_pB | pB | pB | Structure | |
mo_pB/fixed | fixed | Cell of scalars | true | |
mo_pB/start | start | Cell of scalars | ||
mo_setpoint | setpoint | setpoint | Structure | |
mo_setpoint/fixed | fixed | Cell of scalars | true | |
mo_setpoint/start | start | Cell of scalars |
fluidPortA | implicit | Hydraulic port A | input | 1 |
fluidPortB | implicit | Hydraulic port B | input | 2 |
setpoint | implicit | input | 3 | |
Port 4 | implicit | Hydraulic port Leakage | input | mo_useLeakagePort |
