ShuttleValve
    ShuttleValve
HydraulicsByFluidon/Components/Valves/CheckValves
The component ShuttleValve is the model of a changeover valve with Dead volume at each port. It connects port C (the middle port) with the port that has the highest pressure. The flow characteristic is represented by an orifice.
SwitchingThreshold defines deadband to avoid chattering. The shuttle valve switches from A to B when
pressure A > (pressure B + SwitchingThreshold)
and switches from B to A when
pressure A < (pressure B - SwitchingThreshold)
A typical application of this valve is in a load sensing system to determine the highest load pressure.
Note: Due to small volumes between the ShuttleValve and connected components and switching action, a very high numerical stiffness may occur, resulting in small step sizes.
ShuttleValve_0
mo_NominalVolumeFlow
NominalVolumeFlow
Nominal volume flow
Scalar
mo_NominalPressureDifference
Nominal pressure difference
Scalar
mo_ReferenceDensity
ReferenceDensity
Reference density for volume flow and pressure difference
Scalar
mo_SwitchingThreshold
SwitchingThreshold
Pressure threshold to switch between ports
Scalar
mo_deadVolume
deadVolume
Dead volume at ports
Scalar
mo_resistorType
resistorType
Type of the resistor
Structure
mo_resistorType/choice1
Orifice
Number
0
1
mo_resistorType/choice2
Throttle
Number
0
1
ShuttleValve_1
mo_forwardFluidProperties
Forward fluid properties between ports
Scalar
true
false
ShuttleValve_2
mo_pA
pA
pA
Structure
mo_pA/fixed
fixed
Cell of scalars
true
false
mo_pA/start
start
Cell of scalars
mo_pB
pB
pB
Structure
mo_pB/fixed
fixed
Cell of scalars
true
false
mo_pB/start
start
Cell of scalars
mo_pC
pC
pC
Structure
mo_pC/fixed
fixed
Cell of scalars
true
false
mo_pC/start
start
Cell of scalars
fluidPortA
implicit
Hydraulic port A
input
1
fluidPortB
implicit
Hydraulic port B
input
2
fluidPortC
implicit
Hydraulic port C
input
3
