VariableLimiter
Limit the range of a signal with variable limits
Modelica/Blocks/Nonlinear
The Limiter block passes its input signal as output signal as long as the input is within the upper and lower limits specified by the two additional inputs limit1 and limit2. If this is not the case, the corresponding limit is passed as output.
The parameter homotopyType in the Advanced tab specifies the
simplified behaviour if homotopy-based initialization is used:
NoHomotopy: the actual expression with limits is usedLinear: a linear behaviour y = u is assumed (default option)Fixed: it is assumed that the output is fixed at the valueySimplified
If it is known a priori in which region the input signal will be located, this option can help a lot by removing one strong nonlinearity from the initialization problem.
mo_homotopyType | homotopyType | Simplified model for homotopy-based initialization | Structure | |
mo_homotopyType/choice1 | Simplified model = actual model | Number | 0 | |
mo_homotopyType/choice2 | Simplified model: y = u | Number | 0 | |
mo_homotopyType/choice3 | Simplified model: y = ySimplified | Number | 0 |
mo_strict | strict | = true, if strict limits with noEvent(..) | Scalar | true |
mo_ySimplified | ySimplified | Fixed value of output in simplified model | Scalar |
mo_limitsAtInit | limitsAtInit | Has no longer an effect and is only kept for backwards compatibility (the implementation uses now the homotopy operator) | Scalar | true |
mo_u | u | u | Structure | |
mo_u/fixed | fixed | Cell of scalars | true | |
mo_u/start | start | Cell of scalars | ||
mo_y | y | y | Structure | |
mo_y/fixed | fixed | Cell of scalars | true | |
mo_y/start | start | Cell of scalars | ||
mo_limit1 | limit1 | limit1 | Structure | |
mo_limit1/fixed | fixed | Cell of scalars | true | |
mo_limit1/start | start | Cell of scalars | ||
mo_limit2 | limit2 | limit2 | Structure | |
mo_limit2/fixed | fixed | Cell of scalars | true | |
mo_limit2/start | start | Cell of scalars |
u | implicit | Connector of Real input signal | input | 1 |
y | implicit | Connector of Real output signal | output | 1 |
limit1 | implicit | Connector of Real input signal used as maximum of input u | input | 2 |
limit2 | implicit | Connector of Real input signal used as minimum of input u | input | 3 |
