DeMultiplex6
DeMultiplexer block for six output connectors
Modelica/Blocks/Routing
The input connector is split into six output connectors. Note, that the dimensions of the output connector signals have to be explicitly defined via parameters n1, n2, n3, n4, n5 and n6.
mo_n1 | n1 | Dimension of output signal connector 1 | Scalar | |
mo_n2 | n2 | Dimension of output signal connector 2 | Scalar | |
mo_n3 | n3 | Dimension of output signal connector 3 | Scalar | |
mo_n4 | n4 | Dimension of output signal connector 4 | Scalar | |
mo_n5 | n5 | Dimension of output signal connector 5 | Scalar | |
mo_n6 | n6 | Dimension of output signal connector 6 | Scalar |
mo_u | u | u | Structure | |
mo_u/fixed | fixed | Cell of vectors | true | |
mo_u/start | start | Cell of vectors | ||
mo_y1 | y1 | y1 | Structure | |
mo_y1/fixed | fixed | Cell of vectors | true | |
mo_y1/start | start | Cell of vectors | ||
mo_y2 | y2 | y2 | Structure | |
mo_y2/fixed | fixed | Cell of vectors | true | |
mo_y2/start | start | Cell of vectors | ||
mo_y3 | y3 | y3 | Structure | |
mo_y3/fixed | fixed | Cell of vectors | true | |
mo_y3/start | start | Cell of vectors | ||
mo_y4 | y4 | y4 | Structure | |
mo_y4/fixed | fixed | Cell of vectors | true | |
mo_y4/start | start | Cell of vectors | ||
mo_y5 | y5 | y5 | Structure | |
mo_y5/fixed | fixed | Cell of vectors | true | |
mo_y5/start | start | Cell of vectors | ||
mo_y6 | y6 | y6 | Structure | |
mo_y6/fixed | fixed | Cell of vectors | true | |
mo_y6/start | start | Cell of vectors |
u | implicit | Connector of Real input signals | input | 1 |
y1 | implicit | Connector of Real output signals 1 | output | 1 |
y2 | implicit | Connector of Real output signals 2 | output | 2 |
y3 | implicit | Connector of Real output signals 3 | output | 3 |
y4 | implicit | Connector of Real output signals 4 | output | 4 |
y5 | implicit | Connector of Real output signals 5 | output | 5 |
y6 | implicit | Connector of Real output signals 6 | output | 6 |
