Multiplex3
Multiplexer block for three input connectors
Modelica/Blocks/Routing
The output connector is the concatenation of the three input connectors. Note, that the dimensions of the input connector signals have to be explicitly defined via parameters n1, n2 and n3.
mo_n1 | n1 | Dimension of input signal connector 1 | Scalar | |
mo_n2 | n2 | Dimension of input signal connector 2 | Scalar | |
mo_n3 | n3 | Dimension of input signal connector 3 | Scalar |
mo_u1 | u1 | u1 | Structure | |
mo_u1/fixed | fixed | Cell of vectors | true | |
mo_u1/start | start | Cell of vectors | ||
mo_u2 | u2 | u2 | Structure | |
mo_u2/fixed | fixed | Cell of vectors | true | |
mo_u2/start | start | Cell of vectors | ||
mo_u3 | u3 | u3 | Structure | |
mo_u3/fixed | fixed | Cell of vectors | true | |
mo_u3/start | start | Cell of vectors | ||
mo_y | y | y | Structure | |
mo_y/fixed | fixed | Cell of vectors | true | |
mo_y/start | start | Cell of vectors |
u1 | implicit | Connector of Real input signals 1 | input | 1 |
u2 | implicit | Connector of Real input signals 2 | input | 2 |
u3 | implicit | Connector of Real input signals 3 | input | 3 |
y | implicit | Connector of Real output signals | output | 1 |
