Multiplex6
Multiplexer block for six input connectors
Modelica/Blocks/Routing
The output connector is the concatenation of the six input connectors. Note, that the dimensions of the input connector signals have to be explicitly defined via parameters n1, n2, n3, n4, n5 and n6.
mo_n1 | n1 | Dimension of input signal connector 1 | Scalar | |
mo_n2 | n2 | Dimension of input signal connector 2 | Scalar | |
mo_n3 | n3 | Dimension of input signal connector 3 | Scalar | |
mo_n4 | n4 | Dimension of input signal connector 4 | Scalar | |
mo_n5 | n5 | Dimension of input signal connector 5 | Scalar | |
mo_n6 | n6 | Dimension of input signal connector 6 | Scalar |
mo_u1 | u1 | u1 | Structure | |
mo_u1/fixed | fixed | Cell of vectors | true | |
mo_u1/start | start | Cell of vectors | ||
mo_u2 | u2 | u2 | Structure | |
mo_u2/fixed | fixed | Cell of vectors | true | |
mo_u2/start | start | Cell of vectors | ||
mo_u3 | u3 | u3 | Structure | |
mo_u3/fixed | fixed | Cell of vectors | true | |
mo_u3/start | start | Cell of vectors | ||
mo_u4 | u4 | u4 | Structure | |
mo_u4/fixed | fixed | Cell of vectors | true | |
mo_u4/start | start | Cell of vectors | ||
mo_u5 | u5 | u5 | Structure | |
mo_u5/fixed | fixed | Cell of vectors | true | |
mo_u5/start | start | Cell of vectors | ||
mo_u6 | u6 | u6 | Structure | |
mo_u6/fixed | fixed | Cell of vectors | true | |
mo_u6/start | start | Cell of vectors | ||
mo_y | y | y | Structure | |
mo_y/fixed | fixed | Cell of vectors | true | |
mo_y/start | start | Cell of vectors |
u1 | implicit | Connector of Real input signals 1 | input | 1 |
u2 | implicit | Connector of Real input signals 2 | input | 2 |
u3 | implicit | Connector of Real input signals 3 | input | 3 |
u4 | implicit | Connector of Real input signals 4 | input | 4 |
u5 | implicit | Connector of Real input signals 5 | input | 5 |
u6 | implicit | Connector of Real input signals 6 | input | 6 |
y | implicit | Connector of Real output signals | output | 1 |
