VfController
Voltage-Frequency-Controller
    VfController
Modelica/Electrical/Machines/Utilities
Simple Voltage-Frequency-Controller.
Amplitude of voltage is linear dependent (VNominal/fNominal) on frequency (input signal "u"), but limited by VNominal (nominal RMS voltage per phase).
m sine-waves with amplitudes as described above are provided as output signal "y".
By setting parameter EconomyMode=true, Voltage rises quadratically with frequency which means flux,torque and loss reduction for fan and pump drives.
The sine-waves are intended to feed a m-phase SignalVoltage.
Phase shifts between sine-waves may be chosen by the user; default values are (k-1)/m*pi for k in 1:m.
VfController_0
mo_nout
nout
Number of outputs
Scalar
mo_m
m
Number of phases
Scalar
mo_orientation
orientation
Orientation of phases
Vector
mo_VNominal
VNominal
Nominal RMS voltage per phase
Scalar
mo_fNominal
fNominal
Nominal frequency
Scalar
mo_BasePhase
BasePhase
Common phase shift
Scalar
mo_EconomyMode
EconomyMode
Economy mode: voltage quadratic dependent on frquency
Scalar
true
false
mo_pow
pow
Scalar
VfController_1
mo_u
u
u
Structure
mo_u/fixed
fixed
Cell of scalars
true
false
mo_u/start
start
Cell of scalars
mo_y
y
y
Structure
mo_y/fixed
fixed
Cell of vectors
true
false
mo_y/start
start
Cell of vectors
mo_x
x
x
Structure
mo_x/fixed
fixed
Cell of scalars
true
false
mo_x/start
start
Cell of scalars
mo_amplitude
amplitude
amplitude
Structure
mo_amplitude/fixed
fixed
Cell of scalars
true
false
mo_amplitude/start
start
Cell of scalars
u
implicit
Connector of Real input signal
input
1
y
implicit
Connector of Real output signals
output
1
