ElectroMagneticConverterWithLeakageInductance
Electro-magnetic energy conversion with a leakage inductance
Modelica/Magnetic/FluxTubes/Basic
Same as ElectroMagneticConverter with an additional leakage path on the magnetic side (leakage inductance, leakage flux). This model may improve stability especially when the magnetic circuit contains more than one electro-magnetic converter.
mo_N | N | Number of turns | Scalar | |
mo_G_m | G_m | Magnetic permeance of leakage inductance | Scalar | |
mo_eps | eps | Scalar |
mo_L | L | Length in direction of flux | Scalar | |
mo_A | A | Area of cross-section | Scalar | |
mo_mu_rel | mu_rel | Constant relative permeability of leakage inductance (> 0 required) | Scalar |
mo_v | v | v | Structure | |
mo_v/fixed | fixed | Cell of scalars | true | |
mo_v/start | start | Cell of scalars | ||
mo_i | i | i | Structure | |
mo_i/fixed | fixed | Cell of scalars | true | |
mo_i/start | start | Cell of scalars | ||
mo_V_m | V_m | V_m | Structure | |
mo_V_m/fixed | fixed | Cell of scalars | true | |
mo_V_m/start | start | Cell of scalars | ||
mo_Phi | Phi | Phi | Structure | |
mo_Phi/fixed | fixed | Cell of scalars | true | |
mo_Phi/start | start | Cell of scalars | ||
mo_Phi_ind | Phi_ind | Phi_ind | Structure | |
mo_Phi_ind/fixed | fixed | Cell of scalars | true | |
mo_Phi_ind/start | start | Cell of scalars | ||
mo_Phi_leak | Phi_leak | Phi_leak | Structure | |
mo_Phi_leak/fixed | fixed | Cell of scalars | true | |
mo_Phi_leak/start | start | Cell of scalars | ||
mo_Psi | Psi | Psi | Structure | |
mo_Psi/fixed | fixed | Cell of scalars | true | |
mo_Psi/start | start | Cell of scalars | ||
mo_L_stat | L_stat | L_stat | Structure | |
mo_L_stat/fixed | fixed | Cell of scalars | true | |
mo_L_stat/start | start | Cell of scalars |
port_p | implicit | Positive magnetic port | input | 1 |
port_n | implicit | Negative magnetic port | output | 1 |
p | implicit | Positive electrical pin | input | 2 |
n | implicit | Negative electrical pin | output | 2 |
