MultiPhaseElectroMagneticConverter
Multi phase electro magnetic converter
Modelica/Magnetic/FundamentalWave/Components
Each phase
of an
phase winding has an effective number of turns,
and an respective winging angle
and a phase current
The total complex magnetic potential difference of the multi phase winding is determined by:
In this equation each contribution of a winding magnetomotive force on the total complex magnetic potential difference is aligned with the respective orientation of the winding.
The voltages
induced in each winding depend on the cosines between the orientation of the winding and the angle of the complex magnetic flux. Additionally, the magnitudes of the induced voltages are proportional to the respective number of turns. This relationship can be modeled by means of
for
and is also illustrated by the following figure:
See also
SinglePhaseElectroMagneticConverter
mo_effectiveTurns | effectiveTurns | Effective number of turns | Vector | |
mo_orientation | orientation | Orientation of the resulting fundamental wave field phasor | Vector |
mo_v | v | v | Structure | |
mo_v/fixed | fixed | Cell of vectors | true | |
mo_v/start | start | Cell of vectors | ||
mo_i | i | i | Structure | |
mo_i/fixed | fixed | Cell of vectors | true | |
mo_i/start | start | Cell of vectors | ||
mo_abs_V_m | abs_V_m | abs_V_m | Structure | |
mo_abs_V_m/fixed | fixed | Cell of scalars | true | |
mo_abs_V_m/start | start | Cell of scalars | ||
mo_arg_V_m | arg_V_m | arg_V_m | Structure | |
mo_arg_V_m/fixed | fixed | Cell of scalars | true | |
mo_arg_V_m/start | start | Cell of scalars | ||
mo_abs_Phi | abs_Phi | abs_Phi | Structure | |
mo_abs_Phi/fixed | fixed | Cell of scalars | true | |
mo_abs_Phi/start | start | Cell of scalars | ||
mo_arg_Phi | arg_Phi | arg_Phi | Structure | |
mo_arg_Phi/fixed | fixed | Cell of scalars | true | |
mo_arg_Phi/start | start | Cell of scalars |
plug_p | implicit | Positive plug | input | 1 |
plug_n | implicit | Negative plug | output | 1 |
port_p | implicit | Positive complex magnetic port | input | 2 |
port_n | implicit | Negative complex magnetic port | output | 2 |
