GeneralForceToPositionAdaptor
Signal adaptor for a Translational flange with position, speed, and acceleration as outputs and force as input (especially useful for FMUs)
Modelica/Mechanics/Translational/Components
Adaptor between a flange connector and a signal representation of the flange. This component is used to provide a pure signal interface around a Translational model and export this model in form of an input/output block, especially as FMU (Functional Mock-up Unit). Examples of the usage of this adaptor are provided in Translational.Examples.GenerationOfFMUs. This adaptor has force as input and position, velocity and acceleration as output signals.
GeneralForceToPositionAdaptor_0
mo_use_pder
use_pder
Use output for 1st derivative of potential
Number
0
1
mo_use_pder2
use_pder2
Use output for 2nd derivative of potential (only if 1st derivate is used, too)
Number
0
1
mo_use_fder
use_fder
Use input for 1st derivative of flow
Number
0
1
mo_use_fder2
use_fder2
Use input for 2nd derivative of flow (only if 1st derivate is used, too)
Number
0
1
mo_Name_p
Name_p
Name of potential variable
String
mo_Name_pder
Name_pder
Name of 1st derivative of potential variable
String
mo_Name_pder2
Name_pder2
Name of 2nd derivative of potential variable
String
mo_Name_f
Name_f
Name of flow variable
String
mo_Name_fder
Name_fder
Name of 1st derivative of flow variable
String
mo_Name_fder2
Name_fder2
Name of 2nd derivative of flow variable
String
GeneralForceToPositionAdaptor_1
mo_p
p
p
Structure
mo_p/fixed
fixed
Cell of scalars
true
false
mo_p/start
start
Cell of scalars
mo_pder
pder
pder
Structure
mo_pder/fixed
fixed
Cell of scalars
true
false
mo_pder/start
start
Cell of scalars
mo_pder2
pder2
pder2
Structure
mo_pder2/fixed
fixed
Cell of scalars
true
false
mo_pder2/start
start
Cell of scalars
mo_f
f
f
Structure
mo_f/fixed
fixed
Cell of scalars
true
false
mo_f/start
start
Cell of scalars
mo_fder
fder
fder
Structure
mo_fder/fixed
fixed
Cell of scalars
true
false
mo_fder/start
start
Cell of scalars
mo_fder2
fder2
fder2
Structure
mo_fder2/fixed
fixed
Cell of scalars
true
false
mo_fder2/start
start
Cell of scalars
p
implicit
Output for potential
output
1
f
implicit
Input for flow
input
1
flange
implicit
input
2
Port 4
implicit
Optional output for der(potential)
output
mo_use_pder
Port 5
implicit
Optional output for der2(potential)
output
mo_use_pder&&mo_use_pder2
Port 6
implicit
Optional input for der(flow)
input
mo_use_fder
Port 7
implicit
Optional input for der2(flow)
input
mo_use_fder&&mo_use_fder2
