MassWithStopAndFriction
Sliding mass with hard stop and Stribeck friction
Modelica/Mechanics/Translational/Components
This element describes the Stribeck friction characteristics of a sliding mass, i. e. the frictional force acting between the sliding mass and the support. Included is a hard stop for the position.
The surface is fixed and there is friction between sliding mass and surface. The frictional force f is given for positive velocity v by:
f = F_Coulomb + F_prop * v + F_Stribeck * exp (-fexp * v)
The distance between the left and the right connector is given by parameter L. The position of the center of gravity, coordinate s, is in the middle between the two flanges.
There are hard stops at smax and smin, i. e. if flange_a.s >= smin and flange_b.s <= xmax the sliding mass can move freely.
When the absolute velocity becomes zero, the sliding mass becomes stuck, i.e., the absolute position remains constant. In this phase the friction force is calculated from a force balance due to the requirement that the absolute acceleration shall be zero. The elements begin to slide when the friction force exceeds a threshold value, called the maximum static friction force, computed via:
   maximum_static_friction =  F_Coulomb + F_Stribeck
This requires the states Stop.s and Stop.v . If these states are eliminated during the index reduction the model will not work. To avoid this any inertias should be connected via springs to the Stop element, other sliding masses, dampers or hydraulic chambers must be avoided.
For more details of the used friction model see the following reference:
Beater P. (1999):
Entwurf hydraulischer Maschinen. Springer Verlag Berlin Heidelberg New York.
The friction model is implemented in a "clean" way by state events and leads to continuous/discrete systems of equations which have to be solved by appropriate numerical methods. The method is described in (see also a short sketch in UsersGuide.ModelingOfFriction):
Otter M., Elmqvist H., and Mattsson S.E. (1999):
Hybrid Modeling in Modelica based on the Synchronous Data Flow Principle. CACSD'99, Aug. 22.-26, Hawaii.
More precise friction models take into account the elasticity of the material when the two elements are "stuck", as well as other effects, like hysteresis. This has the advantage that the friction element can be completely described by a differential equation without events. The drawback is that the system becomes stiff (about 10-20 times slower simulation) and that more material constants have to be supplied which requires more sophisticated identification. For more details, see the following references, especially (Armstrong and Canudas de Wit 1996):
Armstrong B. (1991):
Control of Machines with Friction. Kluwer Academic Press, Boston MA.
Armstrong B., and Canudas de Wit C. (1996):
Friction Modeling and Compensation. The Control Handbook, edited by W.S.Levine, CRC Press, pp. 1369-1382.
Canudas de Wit C., Olsson H., Åström K.J., and Lischinsky P. (1995):
A new model for control of systems with friction. IEEE Transactions on Automatic Control, Vol. 40, No. 3, pp. 419-425.
Optional heatPort
The dissipated energy is transported in form of heat to the optional heatPort connector that can be enabled via parameter "useHeatPort". Independently whether the heatPort is or is not enabled, the dissipated power is defined with variable "lossPower". If contact occurs at the hard stops, the lossPower is not correctly modelled at this time instant, because the hard stop would introduce a Dirac impulse in the lossPower due to the discontinuously changing kinetic energy of the mass (lossPower is the derivative of the kinetic energy at the time instant of the impact).
MassWithStopAndFriction_0
mo_smax
smax
Right stop for (right end of) sliding mass
Scalar
mo_smin
smin
Left stop for (left end of) sliding mass
Scalar
mo_L
L
Length of component, from left flange to right flange (= flange_b.s - flange_a.s)
Scalar
mo_Unknown
Unknown
Value of mode is not known
Scalar
mo_Free
Free
Element is not active
Scalar
mo_Forward
Forward
v_rel > 0 (forward sliding)
Scalar
mo_Stuck
Stuck
v_rel = 0 (forward sliding, locked or backward sliding)
Scalar
mo_Backward
Backward
v_rel < 0 (backward sliding)
Scalar
mo_unitAcceleration
unitAcceleration
Scalar
mo_unitForce
unitForce
Scalar
mo_m
m
Mass
Scalar
mo_F_prop
F_prop
Velocity dependent friction
Scalar
mo_F_Coulomb
F_Coulomb
Constant friction: Coulomb force
Scalar
mo_F_Stribeck
F_Stribeck
Stribeck effect
Scalar
mo_fexp
fexp
Exponential decay
Scalar
mo_useHeatPort
useHeatPort
=true, if heatPort is enabled
Number
0
1
MassWithStopAndFriction_1
mo_v_small
v_small
Relative velocity near to zero (see model info text)
Scalar
MassWithStopAndFriction_2
mo_v_relfric
v_relfric
v_relfric
Structure
mo_v_relfric/fixed
fixed
Cell of scalars
true
false
mo_v_relfric/start
start
Cell of scalars
mo_a_relfric
a_relfric
a_relfric
Structure
mo_a_relfric/fixed
fixed
Cell of scalars
true
false
mo_a_relfric/start
start
Cell of scalars
mo_f
f
f
Structure
mo_f/fixed
fixed
Cell of scalars
true
false
mo_f/start
start
Cell of scalars
mo_f0
f0
f0
Structure
mo_f0/fixed
fixed
Cell of scalars
true
false
mo_f0/start
start
Cell of scalars
mo_f0_max
f0_max
f0_max
Structure
mo_f0_max/fixed
fixed
Cell of scalars
true
false
mo_f0_max/start
start
Cell of scalars
mo_free
free
free
Structure
mo_free/fixed
fixed
Cell of scalars
true
false
mo_free/start
start
Cell of scalars
mo_sa
sa
sa
Structure
mo_sa/fixed
fixed
Cell of scalars
true
false
mo_sa/start
start
Cell of scalars
mo_startForward
startForward
startForward
Structure
mo_startForward/fixed
fixed
Cell of scalars
true
false
mo_startForward/start
start
Cell of scalars
mo_startBackward
startBackward
startBackward
Structure
mo_startBackward/fixed
fixed
Cell of scalars
true
false
mo_startBackward/start
start
Cell of scalars
mo_locked
locked
locked
Structure
mo_locked/fixed
fixed
Cell of scalars
true
false
mo_locked/start
start
Cell of scalars
mo_s
s
s
Structure
mo_s/fixed
fixed
Cell of scalars
true
false
mo_s/start
start
Cell of scalars
mo_mode
mode
mode
Structure
mo_mode/fixed
fixed
Cell of scalars
true
false
mo_mode/start
start
Cell of scalars
mo_v
v
v
Structure
mo_v/fixed
fixed
Cell of scalars
true
false
mo_v/start
start
Cell of scalars
mo_a
a
a
Structure
mo_a/fixed
fixed
Cell of scalars
true
false
mo_a/start
start
Cell of scalars
mo_lossPower
lossPower
lossPower
Structure
mo_lossPower/fixed
fixed
Cell of scalars
true
false
mo_lossPower/start
start
Cell of scalars
mo_stopped
stopped
stopped
Structure
mo_stopped/fixed
fixed
Cell of scalars
true
false
mo_stopped/start
start
Cell of scalars
flange_a
implicit
Left flange of translational component
input
1
flange_b
implicit
Right flange of translational component
output
1
Port 3
implicit
Optional port to which dissipated losses are transported in form of heat
input
mo_useHeatPort
