VariableSpring
1D rotational spring with variable stiffness
ModelicaExtras/Mechanics/Rotational
A linear 1D rotational spring. The component can be connected either between two inertias/gears to describe the shaft elasticity, or between a inertia/gear and the housing (component Fixed), to describe a coupling of the element with the housing via a spring.
mo_phi_rel0 | phi_rel0 | Unstretched spring angle | Scalar |
mo_c | c | c | Structure | |
mo_c/fixed | fixed | Cell of scalars | true | |
mo_c/start | start | Cell of scalars | ||
mo_phi_rel | phi_rel | phi_rel | Structure | |
mo_phi_rel/fixed | fixed | Cell of scalars | true | |
mo_phi_rel/start | start | Cell of scalars | ||
mo_tau | tau | tau | Structure | |
mo_tau/fixed | fixed | Cell of scalars | true | |
mo_tau/start | start | Cell of scalars |
c | implicit | Variable spring constant | input | 1 |
flange_a | implicit | Left flange of compliant 1-dim. rotational component | input | 2 |
flange_b | implicit | Right flange of compliant 1-dim. rotational component | output | 1 |
