Resistor
Ideal linear electrical resistor
Spice/Analog/Basic
The linear resistor connects the branch voltage v with the branch current i byParameters
sp_R | Resistance | Resistance value at the nominal temperature (ohms) | Scalar | |
sp_Spice | Additional Spice Parameters | For more details, see the section | String |
R+ | implicit | Positive pin | input | 1 |
R- | implicit | Negative pin | input | 2 |
