InitialEventExtract2
new block definition
StateMachine
This block is used to separate the first event of a discrete activation signal from the rest. The first event exists the init port and is usually used for initialization of the state machine. If the block is reset, then the first event following the reset is directed to the init port, and subsequent events to the act port, until possibly a new reset occurs.
