Script Factory
Scripts cannot be executed.
If the path to the batch file or the working directory in ScriptFactory contains spaces, the script cannot be executed (ref.: FXM-16120).
Script Factory does not stop correctly.
Script Factory does not stop correctly if FluxMotor has been killed (ref.: FXM-15140).
Sometimes the store button status is bad.
The store button is not enabled when a file is opened without modification (ref.: FXM-15136).
Script Factory freezes temporarily when running a script.
When running a script, the Script Factory gives the impression of freezing (while still running in the background). The editing window of the script becomes unresponsive until the script is done executing (ref.: FXM-13138).
