SM WF ISP IR 3PH
Wound Field Synchronous Machines - Inner Salient Pole - InnerRotor
Home page view
The Motor Factory – DESIGN area is the first environment of the Motor Factory.
For a synchronous machine with wound field inner salient poles, it is composed of four main zones. This is the guideline for designing your machine.
| Motor Factory – DESIGN area view – Example for synchronous machine with wound field, inner salient pole, and inner rotor | |
| Zone 1 MACHINE |
Definition of general data of the machine depending on the considered
type of machine
| Zone 2 ROTOR |
Access to the main functions to design the ROTOR mainly defined
by:
| Zone 3 STATOR |
Access to the main functions to design the STATOR and its
corresponding subsets:
| Zone 4 MATERIALS | Area to select all the materials required to build the machine, the rotor, and the stator |
| Zone 5 VIEW |
Visualization of the motor radial view. The winding (automatically
defined) is shown.
Note: Graphic functions like
export picture and zoom are available in this view by
right-clicking on mouse (right part of the panel).See system
functions, graphic management to get more
information.
