User Profile
The User Profile tool facilitates a choice of languages for the Compose coding environment.
- To define your user environment for a supported language, from the ribbon, select the User Profile tool.
Select one or more of the supported languages.
Note: R is a supported language but is not packaged with Compose. If you select this user profile, you must install R before attempting to code with it.The corresponding browsers for your language selection are reflected in the View menu. For example, if you select the Python user profile, the View menu options will be set for Python:
Optional Default: Select the default language that will take effect each time
you launch Compose. If you do not select a language, OML is the default.
The default language is reflected in the Preferences as your preferred language:
