GUI Mode
In order to install Altair Flux & FluxMotor Version 2023.1, follow these instructions:
- Close all the applications in use
                Download the Altair
                    Flux & FluxMotor
                    2023.1 installer: hwFluxFluxMotor2023.1_win64.exe
from the Altair One site: https://altairone.com/
And save it locally
 - Run the executable file hwFluxFluxMotor2023.1_win64.exe
- Select a language
 - Click on the OK button
                In the Altair
                        Flux & FluxMotor
                        2023.1 – Windows 64-bit window
                        (License Agreement panel):
- Read through the license agreement and if you accept the terms of the License Agreement, then check the I accept the terms of the License Agreement box
 - Click on the Next button to start with the Altair Flux & FluxMotor 2023.1 installation
                In the next Altair
                        Flux & FluxMotor
                        (Introduction panel):
- Read the introduction and click on the Next button to continue with the Altair Flux & FluxMotor 2023.1 installation
                In the next Altair
                        Flux & FluxMotor
                        (Choose Install Folder panel):
- Choose an installation directory:
- By default:
- with a user account: the installation directory is C:\Users\<username>\Altair\2023.1
 - with an administrator account: the installation directory is C:\Program Files\Altair\2023.1
 - You can specify another installation directory, however, make sure that the full directory path does not include any special characters, then click on the Choose button
 - By default:
 - Click on the Next button to continue with the Altair Flux & FluxMotor 2023.1 installation
                In the next Altair
                        Flux & FluxMotor
                        (Change Shortcut Folder (Local) panel):
- Specify the folder name that will contain the start menu shortcuts.
 - Specify the suffix string to be added to the shortcuts (Optional).
 - Select one of the following options:
- Yes if you want to add the Altair Flux & FluxMotor shortcuts on the desktop
 - No if you do not want to add the Altair Flux & FluxMotor shortcuts on the desktop
                In the next Altair
                        Flux & FluxMotor
                        (Altair License Management System panel):
- Enter the license location:
- If you have a network license, then enter
                                        port@hostname
where port is the TCP/IP port number used by the license server and hostname is the name of the license server computer
 - If you have a local license (standalone license), then enter the full pathname of the license file
                                        port@hostname
Note: This window is only displayed if the license has not yet been configured. - Enter the license location:
                In the next Altair
                        Flux & FluxMotor
                        (Pre-Installation Summary panel):
- Review the installation details and click on the Install button to start the Altair Flux & FluxMotor 2023.1 installation
                In the last Altair
                        Flux & FluxMotor
                        (Install Complete panel):
- Click on the Done button to complete the Altair Flux & FluxMotor 2023.1 installation and exit the installer
