Essential Information about Flux 2023.1
| Essential information about Flux 2023.1 |
In order to use the version, you need:
Flux 2023.1 is available for Windows and Linux OS:
                             The Linux version is qualified with the Gnome Classic with X11 display server. It is highly advisable to use the Gnome Classic with X11 display server to run Flux on Linux.  |
| Flux 2023.1 takes into account the feedback from several users, and around 33 customer issues have been fixed in this version. |
| Distributed computing with MPI is available in Flux for Windows and Linux and can be used with PBS. However, qualification on Windows cluster connected with InfiniBand has not been done and Linux clusters are highly recommended for parallel computing. |
| The ASML Mesher (Altair Solid Meshing Library) is a volume mesher which is the proprietary of Altair. The ASML mesher was integrated with the Flux 2023 release. The MeshGems mesh generator will disappear in a future version. For this Flux 2023.1 release, the both meshers can be used, the default mesher is now ASML. |
| Update of Intel MPI from 2021.8 to 2021.10. |
| Update of MUMPS from 5.5.0 consortium to 5.6.1 consortium. |
| Update of PETSc from 3.17.1 to 3.19.4. |
Minimum memory required:
