About external software – supported version
Supported versions of software whose coupling is possible with Flux
External softwares
The use of external softwares can be achieved with the versions listed in the table below.
| External software | Supported version | Supported OS |
| Simulink | 2019 a&b, 2020 a&b | Windows |
| Matlab | 2019 a&b, 2020 a&b | Windows / Linux |
Altair softwares
The coupling between Flux 2021.1 and other Altair softwares can be achieved with these versions:
| Functionalities | Altair software | supported version (and above) | Windows 10 | Linux (RHEL 8 and SUSE 15.1) |
| Export to .. (Vibroacoustics and mechanical analysis) | OptiStruct | 2021 | ||
| Export to.. (Thermal analysis) | AcuSolve | 2021 | ||
| Co-simulation | Activate | 2021 | ||
| Co-simulation | Compose | 2021 | ||
| Mesh import | HyperMesh | 2021 | ||
| Mesh import | SimLab | 2021 | ||
| Optimization | HyperStudy | 2021 |
ACIS - InterOp : Format and Version Supported
Flux 2021.1 is compatible with ACIS 2019 1.0.1 version.
| Format | Extension | Supported version by ACIS 2017 1.0 |
| ACIS | .sat, .sab, .asat, .asab | R1 – 2019 1.0 |
| CATIA V5 | .CATPart, .CATProduct | V5R8 – V5–6R2019 |
| DXF | .dxf | 2.5 - 2019 |
| IGES | .igs, .iges | Up to 5.3 |
| Inventor | .ipt (V6 – V2017) | V11 – 2019 |
| NX | .prt | 11 – NX 12.0.0 |
| Parasolid | .x_t, .xmt_txt, .x_b, .xmt_bin | 9.0 – 31.1.188 |
| Pro/E /Creo | .prt, .prt.*, .asm, .asm.* | 16 – Creo 5.0 |
| SolidWorks | .sldprt, .sldasm | 98 – 2019 |
| STEP | .stp, .step | AP203, AP214, AP242 |
| Format | Extension | Versions Supported by ACIS 2017 1.0 |
| ACIS | .sat | R18 – 2019 1.0 |
| CATIA V5 | .CATPart, .CATProduct | V5 R15 – V5–6 R2019 |
| IGES | .igs, .iges | 5.3 |
| STEP | .stp, .step | AP203, AP214, AP242 (Geometry only) |
