Describing material media
Introduction
For all that concerns the describing of the material media:
for the magnetic aspects: see chapter Steady State AC Magnetic application: principles
for the thermal aspects: see chapter Thermal applications: principles
Specificities connected with the coupling
Generally speaking, for each modeled area the following should be achieved:
- a magnetic definition
 - a thermal definition
The table below summarizes the main conceivable situations for different parts of the studied device.
| The regions belonging to the study domain… | are defined by... | ||
| (1) |
                         Magnetic and thermal (ex: heated piece or pieces “important” from the thermal point of view)  |
                         a magnetic type:
                         a thermal type:
| (2) |
                         only magnetic (ex: surrounding pieces without influence from the thermal point of view)  |
                         a magnetic type:
                         a thermal type:
| (3) |
                         only thermal (ex: thermal exchange surface with the surrounding air)  |
                         a magnetic type:
                         a thermal type:
In the previously presented example…
- the steel billet is defined from the magnetic and thermal points of view (1)
 - the inductor and the magnetic core are defined only from the magnetic point of view (2)
 - the thermal exchanges surface is defined only from the thermal point of view
                        (3)
