Other available PyFlux commands
Introduction
There are additional commands available to the user that are not accessible by recopying a sequence of PyFlux.
Commands
The available commands are as follows:
- startMacroTransaction() / endMacroTransaction()
 - getProjectName()
 - [ALL]
 - getHelp()
 - getPyFluxCommande()
These commands are described in the next sections.
startMacroTransaction()/endMacroTransaction()
The description and applications of this command are explained in the table below.
| Commands | startMacroTransaction() / endMacroTransaction() |
| Function | Permits the regrouping of a set of commands in a block. |
| Use |
| Example : Pyflux sequence |
                         Creation of a triangle :
| Example : note | The commands are evaluated and the graphics refreshed at the end of the sequence, permitting the acceleration of the process. |
getProject Name()
| Commands | getProjectName() |
| Function | Permits the recovery of the name of the project open in Flux |
| Use | Name= getProjectName() permits the storage of the project name in the ‘Name'variable |
| Example : PyFlux sequence |
                         Display of the Flux project name in a file :
[ALL]
| Commands | [ALL] |
| Function | Creates a the list of all entities of the same type which facilitates the storage of this list in a ‘Flux variable' |
| Use | Points = Point[ALL] creates a list of all entities of the point type and enables the storage of this list in the « Points » variables. |
| Reminder / Comparison |
                         The command List_instance(typeId='Point')* results in the display of all entities of the point type displayed in the History zone. * syntax equivalent to the command List described under § § 5.3.2 Informations sur les entités : Afficher l'expression Pyflux, Lister, et Utiliser par..  |
                         Display of a detailed list of entities belonging to the same entity type in a file:
| Example : result |
                         Content of the created file:
getHelp()
| Commands | getHelp() |
| Function |
                         Permits to stor the help text dealing with an entity type in a « Flux variable ».  |
| Use | Point = Point.getHelp() retrieves the syntax describing the « Point » entity type in order to support storage in the « Point » variable. |
| Reminder / Comparison | The command Point.help() permits the display of the support storage of the Point entity in the history zone. |
                         Display of support related to an entity type in a file:
| Example : result | File created comprising all of the supporting Pyflux command syntax associated with the « Point. » entity type. |
getPyFlux Command()
| Command | getPyFluxCommand() |
| Function | Permits the storage of ann entity in a « Flux variable ». |
| Use | P1=Point[1]. getPyFluxCommand() permits the storage of the Point[1] entity in the « P1 » variable |
| Reminder / Comparison | The command Point[1]. type() permits the display of the entity Point[1] in the history zone |
                         Display of an entity in a file:
| Example : result |
                         Content of created file:
