Path: definition (structure)
Definition of a path
A path is defined by:
- a name (and a comment)
 - a mechanical set (if it is the case)
 - a list of sections
Definition of a section
A section is defined by:
 - a type
 - specific characteristics (depending on the type)
 - a region
 - a discretization
 - color and visibility attributes
Name
The name to identify the path is set by the user during the creation of this one.
A comment (optional) can be added to the name.
Types of sections
The different types of sections and the characteristics useful for their description are presented in the table below.
| Type | Characteristics | |
| section defined by 2 points |
                         point origine (coordonnées)  |
                         point extrémité (coordonnées)  |
| Type | Characteristics | |||||||||||
| arc path defined by 3 points |
                         starting point (coordinates)  |
                         middle point (coordinates)  |
                         ending point (coordinates)  |
| arc defined by center, radius and angles | coordinate system for definition |
                         center point (coordinates)  |
                     radius |
                         starting angle ending angle  |
| parameterized path | coordinate system for definition |
                         functions (coordinates dependent on parameter)  |
                         parameter variation (minimum and maximum)  |
| parameterized path | existing line |
It is not possible to modify a path.
