Local post processing: about
Introduction
The local post processing allows obtaining results starting from computed values in each nodes of the mesh.
The result can be a graphical representation or only a value computed.
Local post processing available
Locally, the user can post process :
- the value of a quantity on a spatial point (session of quantities computation on point)
 - the value of quantity on several spatial points (2D or 3D spatial curve)
 - the color shade of a quantity on a spatial support (Isovalues and Isolines)
 - the vector representation (value and orientation) of a quantity on each nodes of a spatial support (Arrows, Arrows boundary, Arrows path)
Usual quantites
A list of quantities called “usual” is automatically proposed for a local post processing.
This list of quantities changes in function of the studied application.
Two presentations of usual quantities are available:
- one for a post processing giving a graphical result (isovalues, isolines, arrows)
 - one for a post processing giving a no graphical result (point computation, spatial curve)
Non graphical post processing
The presentation of proposed usual quantities for local post processing with a non graphical result (computation point and spatial curve) is presented below:
| Element | Function |
| List of usual quantities |
                         Contains all the exploitable usual quantities. This list is defined and is adapted according to the application studied.  |
| Components list | Contains all the components associated with the selected usual quantity. |
| Corresponding Flux formulas | Contains all Flux formulas equivalent to the added components.* |
Graphical post processing
The presentation of proposed usual quantities for local post processing with a graphical result (isovalues, isolines, arrows) is presented below:
| Liste of usual quantities |
                         Contains usual postprocessed quantities. This list is automatically defined according to the application studied  |
| 1 global component |
                         Contains only one component corresponding to :
| Corresponding Flux formula | Contains the generic Flux formula corresponding of the chosen quantity.* |
