Local quantities available for postprocessing
Introduction
The local quantities available for the postprocessing in the Steady State AC Electric application are stored in two categories:
- usual local quantities : the main characteristic quantities available in direct and easy access
 - “advanced use” local quantities : the secondary quantities available in advanced use
Reminder
The fields of electric potential, electric field intensity, and electric flux density are time harmonic functions:
V(t) = V0ejωt
E(t) = E0ejωt
D(t) = [ε] E(t) ⇒ D(t) = E0ejωt = ([ε'] – j[ε "]) E0 ejωt
Usual local quantities
Usual local quantities available are presented on the table below.
In D* and J*, the "*" means that it is the conjugate of the vector.
Advanced use
Usual local quantities available in advanced use are presented on the table below.
