Local quantities available for postprocessing
Introduction
The local quantities available for the postprocessing in the Steady State AC magnetic application are stored in two categories:
- usual local quantities: the main characteristic quantities available in direct and easy access
 - “advanced use” local quantities: the secondary quantities available in advanced use
Usual local quantities
Usual local quantities available are presented on the table below.
In B*, the "*"means that it is the conjugate of the vector.
Advanced use
Usual local quantities available in advanced use are presented on the table below.
Grandeurs locales pulsée à 2 ω
The force and the torque are time varying quantities that can be decomposed in two components: a time independent component (mean value in time) and a varying component (sinusoidal) of double frequency.
Concerning the surface force and the Laplace's force, Flux provides the quantities presented in the table below.
