The data import/export context in a few words
Definition
- Context dedicated to mechanical coupling
 - Context dedicated to thermal coupling
 - Generic context
The Context dedicated to mechanical coupling allows performing NVH and vibroacoustics coupling with structural analysis software such as Altair OptiStruct.
The Context dedicated to thermal coupling, as well as the mechanical coupling context, is dedicated to the coupling with a third party software of thermal application, Altair AcuSolve software for instance. It allows especially to export Joule losses.
It is a weak coupling. To make a strong magneto-thermal coupling, please refer to the "Dedicated coupling / Magneto-thermal coupling" part presenting the Co-simulation tool available in Multiphysics context.
Generic context
The generic context is addressed to more advanced users.
It contains all the possibilities of the two dedicated contexts presented previously and has the possibility to export any physical quantity which can be computed by Flux.
Access
The data import/export context is available from a Flux project of any physical application and any dimension, before or after solving.
Note: In a Skew application, the context should be used carefully. Especially user should use it only after solving the Skew project.
