Manipulation of the electric circuit components in the standard context
Selection mode
The selection modes are presented in the table below.
| A component of a circuit… | Is selectable … |
| imported |
Select and Edit a component starting from the data tree
To select and then edit a component of the electric circuit starting from the Data tree:
| Step | Action |
| 1 |
                         Select the component in the Data tree:
| → | The component is highlighted |
| 2 |
                         Edit the component in the Data tree:
 or
                         The dialogue box corresponding to the component is opened The user can characterize or modify the circuit component  |
Select and edit a component in the graphic zone CircuitView
To select a component of the electric circuit starting from the graphic zone available on the CircuitView tab:
| Step | Action |
| 1 |
                         Select a component of the circuit:
| 2 |
                         Edit the circuit component:
 or
| → | The dialogue box corresponding the component is opened |
Modifying/ characterizing an electric circuit component
To modify or characterize a component of the electric circuit under the editor (name, comment, model, terminals*):
| Step | Action |
| 1 | Select the desired component |
| 2 | Edit the component or Edit array |
| 3 |
                         Modify the information in the dialogue box:
| 4 |
                         Validate the information:
| → | The component is characterized/modified |
Delete a component in the Data tree
To delete a component starting from the Data tree:
| Step | Action |
| 1 | Select the component to delete |
| 2 |
                         Activate the command:
| → | A confirmation box is opened |
| 3 |
                         Confirm the deletion:
| → | The component is deleted |
