Tools of displaying for curves
In the two contexts, there are tools available for displaying curves. These tools are presented in the following table.
| Display tools | Function |
| Quantity of the curve |
                         Selection of the quantity to display:
| Legend | |
| Scale |
                         Choice between:
| Discretization | Number of curve discretization points Note: The discretization has no
                           influence on spline models curves: the curve is composed by segments
                           linking model's point (spline interpolation in first
                        order)
| Standard tools |
| External data visualization (Edition context) |
Particular case: anisotropic or depending of T
In the case of an anisotropic material or a property depending on the temperature, the material has not only one characteristic curve:
- Anisotropic material: the curves along the axes x, y and z are simultaneously displayed on the same graphic
 - Material with property depending on the temperature: the curve is displayed at the working temperature globally used in the application (see image below)
