Principle of field-circuit coupling
Introduction
We refer to field - circuit coupling or coupling with the circuit equations, whenever the conductors of the finite elements domain are supplied by an external electrical circuit , and the solutions of the electrical circuit and of the magnetic field are not independent of one another.
Coupling principle
The mathematical methods of coupling depend:
- on the one hand, on the formulation used for the magnetic field computation
 - on the other hand, on the method of analysis of the electrical circuit
In all cases, the magnetic field equations and the circuit equations are solved simultaneously.
