Results of iron losses multiparametric computation
Computation results
The multiparametric computation of iron losses gives the following results
I/O Parameters
I/O Parameters called "Inst_iron_losses_i" is stored in the tree, in the area
It represents instantaneous losses on the region(s) versus time, geometric and I/O parameters.
Post-processing iron losses
It is possible to use the previous I/O parameter in order to display iron losses computation.
For instance, it is possible to display a 3D curve of iron losses versus two parameters (time or geometric parameter or I/O parameter) via menu . I/O Parameter called "Inst_iron_losses_i" and containing loss values can be accessed in formula editor (Click on "f()").
Export iron losses
- Select "Inst_iron_losses_i" I/O Parameter that has been created during iron loss computation
 - Choose export format as well as the name of the file
 - Select intervals corresponding to computation intervals
 - Select types of values to be exported. For example:
- Average value (on transient interval). Remark: this is a statistical mean.
 - Current value
 - click on OK
