BATTERY_MODULE
Specifies a battery module and its parameters.
AcuSolve Command
BATTERY_MODULE("name") {parameters...}
number_of_parallel_cells (int) ≥1 [=1]
Number of cells connected in parallel in a battery module for each serial unit. For example, for a 4s2p battery pack the number of parallel cells is 2.
number_of_serial_cells (int) ≥1 [=1]
Number of parallel units connected together in series. For example, for a 4s2p battery pack the number of serial cells is 4.
number_of_parallel_connected_units (int) ≥1 [=1]
Number of parallel connected units in the module configuration. For example, in a 4s2p battery module 2 parallel connected units means two sub-units of size 2s2p are connected.
electrical_input_type (enumerated) [=current]
Type of global electrical input to battery module.
current
Electric current input. Requires current_type.
c_rate
C-rate input. Requires c_rate_type.
voltage
Voltage input. Requires voltage_type = constant.
power
Power input. Requires power_type.
standard_charge_profile
Pre-defined charging profile.
current_type (enumerated) [=none]
Type of electrical current input.
constant or const
Constant electrical current. Requires current.
piecewise_linear or linear
Piecewise linear curve fit electrical current profile. Requires curve_fit_values and curve_fit_variable.
cubic_spline or spline
Cubic spline curve fit electrical current profile. Requires curve_fit_values and curve_fit_variable.
current (real) [=0]
Constant value of electrical current. When current_type is constant. Notice you have positive current for discharging and negative current for charging.
current_curve_fit_values (array) [={0,0}]
A two-column array of independent-variable/isotropic electrical current data values. The independent variable is either state of charge or time. Used with piecewise_linear and cubic_spline types.
current_curve_fit_variable (enumerated) [=time]
Independent variable of the curve fit for isotropic electrical current. Used with piecewise_linear and cubic_spline types.
time
time
c_rate_type (enumerated) [=none]
Type of c-rate input.
none
No c-rate type specified.
constant or const
Constant c-rate value. Requires c_rate.
Piecewise linear curve fit c-rate profile. Requires curve_fit_values and curve_fit_variable.
Cubic spline curve fit c-rate profile. Requires curve_fit_values and curve_fit_variable.
c_rate (real) [=0]
Constant value of c-rate. When type is constant.
c_rate_curve_fit_values (array) [={0,0}]
A two-column array of independent-variable/isotropic c-rate data values. The independent variable is time. Used with piecewise_linear and cubic_spline types.
c_rate_curve_fit_variable (enumerated) [=time]
Independent variable of the curve fit for isotropic c-rate. Used with piecewise_linear and cubic_spline types.
time
time
voltage_type (enumerated) [=constant]
Type of voltage input.
constant or const
Constant voltage value. Requires voltage.
voltage (real) [=0]
Constant value of module input voltage. When voltage_type = constant.
power_type (enumerated) [=constant]
Type of power input.
constant or const
Constant power value. Requires power.
Piecewise linear curve fit power profile. Requires curve_fit_values and curve_fit_variable.
Cubic spline curve fit power profile. Requires curve_fit_values and curve_fit_variable.
power (real) [=0]
Constant value of module input power. When power_type = constant. Input can be positive or negative.
power_curve_fit_values (array) [={0,0}]
A two-column array of independent-variable/isotropic power data values. The independent variable is time. Used with piecewise_linear and cubic_spline types.
power_curve_fit_variable (enumerated) [=time]
Independent variable of the curve fit for power. Used with piecewise_linear and cubic_spline types.
time
time
charging_profile_type (enumerated) [=none]
none
No charging profile used.
constant_current_constant_voltage or cccv
Constant current constant voltage charging profile. Requires a module input current or c_rate to be specified.
constant_power_constant_voltage or cpcv
Constant power constant voltage standard charging profile. Requires module power to be specified.
cut_off_current_percent (real) [=0.01]
Current at which the battery is considered fully charged when using charge profiles.
maximum_cell_voltage (real) [=4.20]
Maximum allowed voltage of an individual battery cell. This avoids overcharging.
minimum_cell_voltage (real) [=3.0]
Minimum allowed voltage of an individual battery cell.
maximum_cell_state_of_charge (real) [=0.95]
State of charge at which a battery cell is considered fully charged.
minimum_cell_state_of_charge (real) [=0.05]
State of charge at which a battery cell is considered fully discharged.
module_id (int) ≥ 0 [=1]
Module ID of battery module in a pack.
battery_pack (string) [=no default]
User-given name of the BATTERY_PACK to which this BATTERY_MODULE belongs.
Battery Modules and Components
The BATTERY_MODULE command specifies parameters related to a battery module (multiple battery cells connected in series and parallel).
BATTERY_MODULE commands are referenced by BATTERY_COMPONENT_MODEL commands, which in turn are referenced by an ELEMENT_SET command.
BATTERY_MODULE( "4s2p battery module" ) {
        number_of_parallel_cells = 2
        number_of_serial_cells = 4
        electrical_input_type = current
        current_type = constant
        current = 20
        number_of_parallel_connected_units = 2
BATTERY_COMPONENT_MODEL( "battery cell" ) {
   battery_module = "4s2p battery module"
BATTERY_COMPONENT_MODEL( "battery positive terminal" ) {
ELEMENT_SET( "battery cell element set" ) {
   Battery_component_model = "battery cell"
ELEMENT_SET( "terminal element set" ) {
   Battery_component_model = "battery positive terminal"
Cell Electrical Connectivity
The number of parallel and serial cells, number_of_parallel_cells and number_of_serial_cells respectively, are defined by their electrical connectivity, for example a pouch module made up of 8 cells in a 4s2p configuration would be:
Where four pairs of parallel connected cells: 1&2, 3&4, 5&6, and 7&8, are connected in series to make up the module configuration 4s2p. Alternatively, for a cylindrical module, with 48 cells in an 8s6p configuration:
Each set of 6 cells, for example, 1-6 or 7-12, are connected in parallel. These banks of parallel cells are then connected in series, for example, cells 1-6 are connected in series to cells 7-12. The number_of_parallel_connected_units is how many PCUs (parallel connected unit) you have in the configuration. Conceptually a PCU and an SCU, given by PCU being equal to the number of serial connected cells, is demonstrated in the following figure:
Figure 3. Battery Module Configurations
For example, in a 4s2p case, where the number_of_parallel_connected_units = 1, 2 or 4. The corresponding electrical connection of the battery cells would be:
Figure 4. Example PCU Configurations
Multi-Battery Module Treatment
In a battery module, batteries are connected in a nSmP pattern, for example, 8s6p, where m batteries are connected in parallel and then n of these parallel connected units are connected in serial to form a pack. In the MSMD method, two potential equations are solved for the ϕ 1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqy1dy2aaS baaSqaaiaaigdaaeqaaaaa@38A6@ and ϕ 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqy1dy2aaS baaSqaaiaaikdaaeqaaaaa@38A7@ electrical field. Depending on battery connectivity, ϕ 1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqy1dy2aaS baaSqaaiaaigdaaeqaaaaa@38A6@ and ϕ 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqy1dy2aaS baaSqaaiaaikdaaeqaaaaa@38A7@ could be the potential from the positive current collector or the negative one. Therefore, in a battery module simulation, the two potential equations are solved with the transfer current density changing sign dependent on the location in the module. The cells are alternating as odd and even stages. See figure 4. In tabs and busbars, you only solve for one of the fields. In figure 4, the ϕ 1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqy1dy2aaS baaSqaaiaaigdaaeqaaaaa@38A6@ and ϕ 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqy1dy2aaS baaSqaaiaaikdaaeqaaaaa@38A7@ on the left indicates which field was solved in the tabs/busbars in the line. The governing equations for the cell scale become:(1)
∇ ( σ ∇ ϕ ) = j MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaey4bIe9aae WaaeaacqaHdpWCcqGHhis0cqaHvpGzaiaawIcacaGLPaaacqGH9aqp caWGQbaaaa@400C@
For ϕ 1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqy1dy2aaS baaSqaaiaaigdaaeqaaaaa@38A6@ in an odd stage:(2)
σ = σ + MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4WdmNaey ypa0Jaeq4Wdm3aaSbaaSqaaiabgUcaRaqabaaaaa@3B91@
(3)
j = − I / V MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOAaiabg2 da9maalyaabaGaeyOeI0IaamysaaqaaiaadAfaaaaaaa@3A98@
For ϕ 1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqy1dy2aaS baaSqaaiaaigdaaeqaaaaa@38A6@ in an even stage:(4)
σ = σ − MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4WdmNaey ypa0Jaeq4Wdm3aaSbaaSqaaiabgkHiTaqabaaaaa@3B9C@
(5)
j = I / V MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOAaiabg2 da9maalyaabaGaamysaaqaaiaadAfaaaaaaa@39AB@
For ϕ 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqy1dy2aaS baaSqaaiaaikdaaeqaaaaa@38A7@ in an odd stage:(6)
(7)
For ϕ 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqy1dy2aaS baaSqaaiaaikdaaeqaaaaa@38A7@ in an even stage:(8)
(9)
Figure 5. Odd and Even Stages for Cell
Cell Current/Voltage Calculation in Module
To model serial and parallel connected modules, state and model information is needed for each individual cell. The module current I k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaCa aaleqabaGaam4Aaaaaaaa@37E2@ is given, but the individual current through each battery ( I j k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaDa aaleaacaWGQbaabaGaam4Aaaaaaaa@38D1@ ) is needed for the electric potential equation, energy equation, ECM model, and the voltage across each PCU as the reference potential. As an example, suppose two PCUs are connected in series. Then the electrical circuit diagram would be as follows:
Figure 6. Battery Pack Current and Voltage
To get current and voltage distribution over each cell, the terminal voltage is separated into a "fixed" part ( V j k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvamaaDa aaleaacaWGQbaabaGaam4Aaaaaaaa@38DE@ ) and a "variable" part.(10)
V = V fixed + V variable MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvaiabg2 da9iaadAfadaWgaaWcbaGaaeOzaiaabMgacaqG4bGaaeyzaiaabsga aeqaaOGaey4kaSIaamOvamaaBaaaleaacaqG2bGaaeyyaiaabkhaca qGPbGaaeyyaiaabkgacaqGSbGaaeyzaaqabaaaaa@46CF@
(11)
V fixed = V o     c − ∑ i R i I R k = V j k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvamaaBa aaleaacaqGMbGaaeyAaiaabIhacaqGLbGaaeizaaqabaGccqGH9aqp caWGwbWaaSbaaSqaaiaab+gacaaMc8UaaGPaVlaabogaaeqaaOGaey OeI0YaaabuaeaacaWGsbWaaSbaaSqaaiaabMgaaeqaaOGaamysamaa DaaaleaacaWGsbaabaGaam4Aaaaakiabg2da9iaadAfadaqhaaWcba GaamOAaaqaaiaadUgaaaaabaGaamyAaaqab0GaeyyeIuoaaaa@4F51@
(12)
V variable = R 0 I j k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvamaaBa aaleaacaqG2bGaaeyyaiaabkhacaqGPbGaaeyyaiaabkgacaqGSbGa aeyzaaqabaGccqGH9aqpcaWGsbWaaSbaaSqaaiaabcdaaeqaaOGaam ysamaaDaaaleaacaWGQbaabaGaam4Aaaaaaaa@4406@
Everything is known for the "fixed" part from the last time step, the reference potential Vk can be calculated across any PCU based on the following equation. Ik is the pack charging/discharging current, which is an input.(13)
V K = ∑ j V j k R j − I k ∑ j 1 R j MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvamaaCa aaleqabaGaam4saaaakiabg2da9maalaaabaWaaabeaeaadaWcaaqa aiaadAfadaqhaaWcbaGaamOAaaqaaiaadUgaaaaakeaacaWGsbWaaS baaSqaaiaadQgaaeqaaaaaaeaacaWGQbaabeqdcqGHris5aOGaeyOe I0IaamysamaaCaaaleqabaGaam4AaaaaaOqaamaaqababaWaaSaaae aacaaIXaaabaGaamOuamaaBaaaleaacaWGQbaabeaaaaaabaGaamOA aaqab0GaeyyeIuoaaaaaaa@4919@
(14)
I j k = V j k − V k ∑ j R s , j MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaDa aaleaacaWGQbaabaGaam4Aaaaakiabg2da9maalaaabaGaamOvamaa DaaaleaacaWGQbaabaGaam4AaaaakiabgkHiTiaadAfadaWgaaWcba Gaam4AaaqabaaakeaadaaeqaqaaiaadkfadaWgaaWcbaGaam4Caiaa cYcacaWGQbaabeaaaeaacaWGQbaabeqdcqGHris5aaaaaaa@4631@
I j k I R k I j k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaDa aaleaacaWGQbaabaGaam4AaaaakiaadMeadaqhaaWcbaGaamOuaaqa aiaadUgaaaGccaWGjbWaa0baaSqaaiaadQgaaeaacaWGRbaaaaaa@3E81@ is then used in the subscale model to calculate I R k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaDa aaleaacaWGsbaabaGaam4Aaaaaaaa@38B9@ , R 1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaBa aaleaacaaIXaaabeaaaaa@37B5@ , C 1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaBa aaleaacaaIXaaabeaaaaa@37A6@ is the polarization resistance and capacitance from the first pair, R 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaBa aaleaacaaIYaaabeaaaaa@37B6@ , C 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaBa aaleaacaaIYaaabeaaaaa@37A7@ is the polarization resistance and capacitance from the second pair, I R 1 k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaDa aaleaacaWGsbWaaSbaaWqaaiaaigdaaeqaaaWcbaGaam4Aaaaaaaa@39AC@ , I R 2 k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaDa aaleaacaWGsbWaaSbaaWqaaiaaikdaaeqaaaWcbaGaam4Aaaaaaaa@39AD@ , I R 1 k + 1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaDa aaleaacaWGsbWaaSbaaWqaaiaaigdaaeqaaaWcbaGaam4AaiabgUca Riaaigdaaaaaaa@3B49@ , I R 2 k + 1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaDa aaleaacaWGsbWaaSbaaWqaaiaaikdaaeqaaaWcbaGaam4AaiabgUca Riaaigdaaaaaaa@3B4A@ are diffusion resistor current at time step k and k+1.(15)
I R 1 k + 1 = exp ( − Δ t R 1 C 1 ) I R 1 k + ( 1 − exp ( − Δ t R 1 C 1 ) ) I j k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaDa aaleaacaWGsbWaaSbaaWqaaiaaigdaaeqaaaWcbaGaam4AaiabgUca RiaaigdaaaGccqGH9aqpciGGLbGaaiiEaiaacchadaqadaqaamaala aabaGaeyOeI0IaeyiLdqKaamiDaaqaaiaadkfadaWgaaWcbaGaaGym aaqabaGccaWGdbWaaSbaaSqaaiaaigdaaeqaaaaaaOGaayjkaiaawM caaiaadMeadaqhaaWcbaGaamOuamaaBaaameaacaaIXaaabeaaaSqa aiaadUgaaaGccqGHRaWkdaqadaqaaiaaigdacqGHsislciGGLbGaai iEaiaacchadaqadaqaamaalaaabaGaeyOeI0IaeyiLdqKaamiDaaqa aiaadkfadaWgaaWcbaGaaGymaaqabaGccaWGdbWaaSbaaSqaaiaaig daaeqaaaaaaOGaayjkaiaawMcaaaGaayjkaiaawMcaaiaadMeadaqh aaWcbaGaamOAaaqaaiaadUgaaaaaaa@5D89@
(16)
I R 2 k + 1 = exp ( − Δ t R 2 C 2 ) I R 2 k + ( 1 − exp ( − Δ t R 2 C 2 ) ) I j k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysamaaDa aaleaacaWGsbWaaSbaaWqaaiaaikdaaeqaaaWcbaGaam4AaiabgUca RiaaigdaaaGccqGH9aqpciGGLbGaaiiEaiaacchadaqadaqaamaala aabaGaeyOeI0IaeyiLdqKaamiDaaqaaiaadkfadaWgaaWcbaGaaGOm aaqabaGccaWGdbWaaSbaaSqaaiaaikdaaeqaaaaaaOGaayjkaiaawM caaiaadMeadaqhaaWcbaGaamOuamaaBaaameaacaaIYaaabeaaaSqa aiaadUgaaaGccqGHRaWkdaqadaqaaiaaigdacqGHsislciGGLbGaai iEaiaacchadaqadaqaamaalaaabaGaeyOeI0IaeyiLdqKaamiDaaqa aiaadkfadaWgaaWcbaGaaGOmaaqabaGccaWGdbWaaSbaaSqaaiaaik daaeqaaaaaaOGaayjkaiaawMcaaaGaayjkaiaawMcaaiaadMeadaqh aaWcbaGaamOAaaqaaiaadUgaaaaaaa@5D8F@
Electrical Input Type
Different types of electrical input can be included as an input to the battery module using the electrical_input_type command. These are summarized in the following sections.
Current
Current supports both generic charging and discharging, these include: constant; piecewise_linear; cubic_spline; and current profiles.
The following gives an example input for a current profile:
BATTERY_MODULE( "4S2P battery module" ) {
    current_type = piecewise_linear
    current_curve_fit_values = Read( "time_current.txt" )
    current_curve_fit_variable = time
    cut_off_current_percent = 0.1
    maximum_cell_voltage = 4.2
    minimum_cell_voltage = 2.7
    minimum_cell_state_of_charge = 0.05
    maximum_cell_state_of_charge = 0.95
And time_current.txt would look like this:
0               0.66809696
9.61104062      0.66809696
12.5842409      0.66809696
13.34691228     15.37136268
Figure 7 shows a typical driving profile with current input. Figure 8 shows the voltage and soc response from this particular current input. The driving profile is taken from [1].
Figure 7. Current Input for a Driving Profile
Figure 8. Voltage and soc Output for a Driving Profile
[1] Mahfoudi, Nadjiba, et al. "Thermal Analysis of LMO/Graphite Batteries Using Equivalent Circuit Models." Batteries 7.3 (2021): 58.
C-Rate
C-rate supports both generic charging and discharging, these include: constant; piecewise_linear; cubic_spline; and c-rate profiles.
C-rate is the speed at which a battery is charged/discharged. For example, if you have a battery with a capacity of 3.5Ah, then you can calculate how many amps it can provide for different charging or discharging rates. Below are some examples:
  • Battery with capacity of 3.5Ah discharged at a c rate of 0.5C delivers 1.75A for 2 hours.
  • Battery with capacity of 3.5Ah discharged at a c rate of 1C delivers 3.5A for 1 hour.
  • Battery with capacity of 3.5Ah discharged at a c rate of 2C delivers 7A for 30 mins.
To define a constant c-rate for a 1C discharge the BATTERY_MODULE would be:
    electrical_input_type = c_rate
    c_rate = 1
Charging Profiles
For charging profiles, you can have CC-CV or CP-CV. For CC-CV the charging starts with a constant current, or c_rate, and then switches to a constant voltage charging method once the voltage limit is reached. The simulation will terminate when the current drops to a pre-defined level, for example, minimum current or maximum soc. For CP-CV, the initial charging is constant power and switches to constant voltage once the voltage limit is reached. The CP-CV charging terminates in the same manner as CC-CV. A typical CC-CV or CP-CV charging current, voltage and soc curve are shown in the following figures.
Figure 9. Voltage and Current Single Cell Responses for CC-CV and CP-CV Charging
Figure 10. Single Cell soc Response for CC-CV and CP-CV Module Charging
Example CC-CV input: For a CC-CV input, the following parameters need to be defined:
  • electrical_input_type = standard_charge_profile
  • charging_profile_type = constant_current_constant_voltage
  • current/c_rate
The following parameters can typically be taken to be default:
  • cut_off_current_percent
  • maximum_cell_voltage
  • minimum_cell_voltage
  • minimum_cell_state_of_charge
  • maximum_cell_state_of_charge
    current = -20
    minimum_cell_voltage = 3.0
Example input CP-CV: The input for CP-CV the following parameters need to be defined:
  • charging_profile_type = constant_power_constant_voltage
  • power
    power = 300
Constant Power (CP)
CP is charging with constant power, for example, power_type = constant.
Example input CP: For a CP input, the following parameters need to be defined:
  • electrical_input_type = power
  • power
    power = 300
Constant Voltage (CV)
CV is charging with constant voltage, for example, voltage_type = constant. The input module voltage divided by the number of parallel cells should be between the minimum and maximum cell voltage.
Example input CV: For a CV input, the following parameters need to be defined:
  • electrical_input_type = voltage
  • voltage
    voltage = 16
