FIELD_BOUNDARY_CONDITION
Specifies field quantity for boundary conditions.
AcuSolve Command
FIELD_BOUNDARY_CONDITION("name") {parameters...}
Qualifier
User-given name.
- type (enumerated) [=value]
- Mesh motion type. - value
- Uniform value.
- field (string) [=none]
- User-given name of a field. The field entry must be listed in the EQUATION::FIELDS entry.
- multiplier_function (string) [=none]
- User-given name of the multiplier function used to scale the field value.
- value (real) [=0]
- Uniform value for the specified field.
FIELD_BOUNDARY_CONDITION( "inlet water" ) {
   field         = "water"
   type          = value
   value         = 1
