RUN
Processes the input data for the particle trace solver.
AcuTrace Command
RUN {parameters}
Qualifier
This command has no qualifier.
ignore_input_error (boolean) [=off]
Flag specifying whether to ignore any errors that occur while reading the preceding commands. If off and an error has occurred, this command is not processed.
The purpose and function of this command is identical to the AcuSolve command of the same name. Refer to the AcuSolve Command Reference Manual for details.
