udfGetElmWDetJ()
Return the weighted determinant of the element Jacobian at the quadrature point.
wghtDetJac = udfGetElmWDetJ( udfHd ) ;
User Defined Element
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- wghtDetJac (Real*)
- Pointer to one dimensional real array of the weighted determinant of the Jacobian at the element quadrature point. The array dimension is the number of elements, nItems.
Real* wghtDetJac ;
Real wDetJ ;
Integer elem ;
for ( elem = 0 ; elem < nItems ; elem++ ) {
wDetJ = wghtDetJac[elem] ;
}Errors
- This routine expects a valid udfHd.
- This routine may only be called within a Body Force, Material Model or Component Model user function.
