udfGetType()
Get the type of the user-defined function.
type = udfGetType( udfHd ) ;
AcuSolve User-Defined Function Basic
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- type (integer)
- The returned type can have several different values, depending on the
user-defined function type:
- Returned Type Value
- Meaning of Type Value
- UDF_MULT_FUNCTION
- Multiplier function.
- UDF_NODAL_BC
- Nodal boundary condition.
- UDF_NODAL_BC_DIR
- Nodal BC direction vector.
- UDF_PERIODIC_BC
- Periodic boundary condition.
- UDF_ELEMENT_COMPONENT
- Element component (fan or heat exchanger).
- UDF_ELEMENT_BC
- Element boundary condition.
- UDF_VISCOSITY
- Element viscosity.
- UDF_CONDUCTIVITY
- Element thermal conductivity.
- UDF_DIFFUSIVITY
- Element species diffusivity.
- UDF_GRAVITY
- Element gravity (generalized volumetric body force).
- UDF_MASS_HEAT_SOURCE
- Element heat source per unit mass.
- UDF_VOLUME_HEAT_SOURCE
- Element heat source per unit volume.
- UDF_MASS_SPECIES_SOURCE
- Element species source per unit mass.
- UDF_VOLUME_SPECIES_SOURCE
- Element species source per unit volume.
- UDF_EMISSIVITY
- Radiation surface emissivity.
- UDF_DENSITY
- Element density.
- UDF_SPECIFIC_HEAT
- Element enthalpy.
- UDF_MESH_MOTION
- Mesh motion.
- UDF_ELEMENT_OUTPUT
- Element output.
- UDF_SURFACE_TENSION
- Surface tension.
- UDF_CONTACT_ANGLE
- Contact angle.
- UDF_FLEXIBLE_BODY
- Flexible body.
- UDF_VISCOELASTIC
- Viscoelastic model.
Integer type ;
UDF_PROTOTYPE(usrFunc) ;
if ( type == UDF_VISCOSITY ) {
/* compute viscosity */
} else if ( type == UDF_CONDUCTIVITY ) {
/* compute thermal conductivity */
} else {
udfSetError( udfHd, "Invalid type %d", type ) ;
}Errors
This routine expects a valid udfHd as an argument. An invalid argument returns an error.
