Introduction of background knowledge regarding flow physics and CFD as well as detailed information about the use of AcuSolve and what specific options do.
Collection of AcuSolve simulation cases for which results are compared against analytical or experimental results to demonstrate the accuracy
of AcuSolve results.
AcuSolve contains a number of command line utility scripts that can be used for pre-processing the model, post-processing
the model, running the model, and for monitoring the solution as it progresses.
