ACU-T: 4003 Freely Falling Water Droplet
Prerequisites
This tutorial introduces you to the workflow for setting up a transient droplet simulation using HyperMesh CFD. Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 UI Introduction, and have a basic understanding of HyperMesh CFD and AcuSolve. To run this simulation, you will need access to a licensed version of HyperMesh CFD and AcuSolve.
Problem Description
Validate the Geometry
Figure 3.
Set Up Flow
Create Materials
Assign Material Properties
Generate the Mesh
Define Nodal Outputs and Nodal Initial Conditions
In this step, you will define the nodal output frequency and then specify the nodal initial conditions for the water droplet.
Define Nodal Output Frequency
Define Nodal Initial Conditions
Run AcuSolve
Post-Process the Results with HM-CFD Post
Summary
In this tutorial, you successfully learned how to set up and solve a simulation involving contact angle and surface tension using HyperMesh CFD. You imported the geometry and then defined the simulation parameters and flow boundary conditions. Once the solution was computed, you used HyperMesh CFD Post to create the contours of volume fraction of water
